| Version(s): | through 08.11.13.96 | ||
| Area: | N\A | ||
| Subarea: | N\A |
Why are schematic design, output, and other tools not discussed in the Bentley Substation Help file?
Where is the promis.e User Manual?
Tools common to both Promis.e and Bentley Substation are discussed in the Help file for Promis.e. If a tool found in the Tasks area of Bentley Substation is not covered in the Help file for Bentley Substation, check the Promis.e Help file.
The User Manual, formerly available in PDF format, is available as the Help file. The Help file contains the same information as the User Manual did.
Press the Help button that is present on most dialogs, or
Press the F1 key on the keyboard, or
From the Welcome to dialog, select the Getting Started tab then click the promis-e User Manual link, or
From the main pull down menus select Help > Contents, or
Use Windows Explorer to browse to the following folder or similar
C:\Program Files (x86)\Bentley\promise V8i\Documentation\
Double-click the phelp.chm file to open.
In Bentley Substation V8i SELECTseries 8, the Promis.e Help is integrated with Bentley Substation Help.
For Bentley Substation V8i SELECTseries 7 and earlier:
Or, for better use of the Index and Search tabs:
C:\Program Files (x86)\Bentley\Substation V8i\Documentation\
| Original Author: | Matt_P |
Keywords: chm, user guide, system manual
