| Version(s): | 08.11.12 | ||
| Area: | Project Management | ||
| Subarea: | Backup and Restore Project |
When using [[Restore Project]] to restore a project backup file, the following message is displayed:
Information
There are error during restore, please try to rebuild this project to fix it.
There is missing or incorrect data in the database in the backup file (.PRJ) being restored. When the message is acknowledged by selecting OK, the software will skip the related problem records so that the restore process can continue. To try to repair the missing data, rebuild the project.
After performing either procedure below, there may be some outstanding issues that have to be addressed by the user as they are found.
After dismissing the error message and the project is restored, right-click the project in [[Project Manager]] and select Rebuild Project Database.
| Original Author: | Matt_P |
