Missing rebar level colors in Sheets
 Product(s):ProConcrete
 Version(s):CONNECT Edition (10.xx.00.xx)
 Environment:N/A
 Area:Plotting
 Subarea:Rebar Colors
 Original Author:Kemuel Jancorda, Bentley Product Advantage Group
Problem Description
User wants to plot rebar level colors from 3D Rebar Elements to Plotting Sheets. Even though Display Rules are set, user reported that colors are missing as displayed in the Print Preview and in the sheet output.
Steps to Resolve
In the References dialog under 2D Drawing models, Synchronize View settings may be set to "Settings from the Design Model".
It is recommended to modify the abovementioned settings to resolve the issue.
