| Version(s): | through 08.11.13.140 | ||
| Area: | Project Management | ||
| Subarea: | Backup and Restore Project |
When attempting to [[Restore Project|restore]] a particular project backup file (.PRJ) the following error message is displayed, halting the restore.
Internal Error
Error Message: Index was outside the bounds of the array.
TargetSite: System.String.GetProjectMDBPath(System.String)
DeclaringType: Bentley.Electrical.API.Base.RestoreServiceBase
Attributes: public virtual
MemberType: Method
This error message can occur when the ECADProject.mdb file has been stripped or quarantined from the PRJ file. Sending a PRJ file through e-mail can result in such quarantining.
Use an online file sharing service or USB drive to transfer the PRJ file instead of e-mail.
| Original Author: | Matt_P |
