| Version(s): | through 10.01.00.23 | ||
| Area: | Project Management | ||
| Subarea: | Backup and Restore Project |
The Restore Project tool restores a project from a backup file made with the [[Backup Project]] tool. The backup files will have a .PRJ extension. Backup files are forwards compatible, meaning they can typically be restored in the same or more recent versions of the software, but cannot be restored in earlier versions of the software.
In [[Project Manager]], right-click a workset and select Restore from the pop up. This means a workset must be created before restoring a project backup.
Select [[Project Manager]] > File > Restore
[[Backup Project]]
[[5353|Error - Unable to restore project, project's database version is newer]]
communities.bentley.com/.../273550
| Original Author: | Matt_P |
Keywords: archive
