| Version(s): | 08.11.11.616 | ||
| Area: | N/A | ||
| Subarea: | N\A |
Before you start import SDNF:
Find and replace Beam, Column… in the sdf file to the corresponding shape description in the fdf file
All shapes will be imported to the assigned levels, also note that if you assign linetypes and colors to the fdf file they should also be applied.
Note: pay special attention to case and names when editing the SDNF and FDF files.
| Original Author: | Jitender Singh Sansoa |
