| Product(s): | ProSteel/ProStructures | ||
| Version(s): | ALL | ||
| Area: | Manipulation Tools | ||
| Subarea: | N/A | ||
| Original Author: | Roger Belen, Bentley Technical Support Group | ||
Setting the default template to use when opening ProSteel/ProStructures assures CAD managers that users are starting the project with the correct settings and units.
How to set the default .DWT Template within ProSteel/ProStructures ICON?
If you go into the properties of the ProSteel/ProStructures Icon.
You can change the Template that you want to use when the software opens.
