Add leading zeros to numbers on reports
 Product(s):Promis.e, Bentley Substation
 Version(s):through 08.11.13.73
 Environment:N/A
 Area:Template Management
 Subarea:Report Template Designer
This document describes how to force numbers to be displayed as a specified number of digits on a report by using a script in the report template. The script adds the necessary amount of leading zeros to the numbers.
Copy the following script and paste it as the contents of the [[Before Print scripts for report templates|BeforePrint script]] for the table cell or label that displays the number:
int number;
string value = (sender as XRLabel).Text;
bool result = Int32.TryParse(value, out number);
if (result)
   (sender as XRLabel).Text = number.ToString("D3");
else
   (sender as XRLabel).Text = value;
Notes:
The "D3" argument in the script sets the number of digits to 3.  Change the 3 to the desired number of digits.
If the number is not an integer value it will be displayed in its original format.
External Links
How to: Pad a Number with Leading Zeros
 Original Author:John Spathaky
Keywords: text on drawing, losing, drop, wire number, page number
P/S: 68481, 500000086444
