| Product(s): | ProSteel for AutoCAD |
| Version(s): | V8i and CONNECT Edition |
| Environment: | N/A |
| Area: | Elevation Flags |
| Subarea: | N/A |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
While placing Elevation Flags in the model, the same is displayed with an extra diagonal line in the 2D drawing. How to get rid of that ?
1) Initially, while inserting the Elevation Flags in the 3D model, make sure to turn off the Guideline option when setting up the Elevation Style Display
This will eliminate the extra diagonal line or guide line that appears in the Elevation Flag.
2) Alternatively, if this issue appears in already placed 2D drawings, one must select all the Elevation Symbols in the 2D drawings and open its PS Properties. Then, in the Layout tab, uncheck the Guidelines option.
This should then eliminate the display of the extra Guideline that was appearing in the Elevation Flag placed.
