| | Product(s): | Promis.e, Bentley Substation | |
| | Version(s): | through 10.00.00.232 | |
| | Environment: | N/A | |
| | Area: | Template Management | |
| | Subarea: | Report Template Designer | |
Report Template Designer is used to create and modify report templates (.RPT files) for use with [[Run Reports]].
To open the Report Template Designer
* is used to denote a menu selection that is not necessary for some versions or platforms.
Bentley Substation CONNECT Edition
- Select Output ribbon tab > Reports group > Report Template Designer
- Function key shortcut: F2 > O > RY
- If the Output ribbon tab is already the active tab: F3 > RY
V8i SELECTseries 5 through 8
- From the Tasks or ribbon area, select Manage > *Template Management > Report Template Designer
- Key-in: ECAD EXEC REPORTWIZARD
- Key-in for promis.e for AutoCAD (through SS7): ECAD_EXEC_REPORTWIZARD
V8i through SELECTseries 3
- From the Tasks or ribbon area, select Configure > *Output Templates > Report Template Designer
promis.e 2007
- Select Elec-Tools > Report Template Designer
For more information
See the Report Template Designer section in Help.
For Bentley Substation CONNECT Edition, see the Report Template Designer of online Help for Bentley Substation available from Bentley Product Documentation.
[[Run Reports]]
[[Open Run Reports Faster]]
