| Product(s): | ProSteel | ||
| Version(s): | N/A | ||
| Area: | |||
| Subarea: | N/A | ||
| Original Author: | Detlef Hackbarth, Bentley Technical Support Group | ||
The new ProStructures V8i SELECTseries 6 Version doesn't show bolts in the expected way; the reason is that bolts became a new object type which has to be taken in consideration in the Detailstyles.
