| | Product(s): | ProStructures | |
| | Version(s): | 08.11.11.297 | |
| | Environment: | N\A | |
| | Area: | N/A | |
| | Subarea: | N\A | |
Is it possible to show elements created with tools: Smart line, Place block and Place Shape in 2DDC - Isometric views. If yes, how?
This can be done by using ProStrucutre Create Partlist Element" Command and adding intelligent to the element.
1st: using ProStrucutre "Create Partlist Element" command to add intelligent to elements
2nd: open ProStrucutre detail center.
3rd: Edit detail style, under the 2D display - common check "special part" option.
See attach avi for steps.
| | Original Author: | Jitender Singh Sansoa | |
