| Product(s): | ProSteel 3D Professional | ||
| Version(s): | N\A | ||
| Area: | General | ||
| Subarea: | N\A | ||
| Original Author: | Detlef Hackbarth, Bentley Technical Support Group | ||
In some cases you might fall into the "view-depth-trap" :-)
Your situation and your detail (View_1) WITHOUT hidden holes:
You have to increase the view depth either in the Detail Style (above) or the View frame's properties (below and recommended):
Result of the detailing WITH hidden holes:
