| Product(s): | ProSteel |
| Area: | Drawing Production |
| Subarea: | Automatic 2D Cut |
| Original Author | Steffen Knoll, Bentley Technical Support Group |
| Updated By: | Vyanktesh Nama, Bentley Technical Support Group |
This wiki explains how to change position, direction and cut depth of automatic cuts.
1. Automatic cuts are saved as modifications. So, open PS Properties of the shape and go to Modifications > 2D-Cuts
2. Here you can change cut depth, cut direction and the position.
3. When you select the shape now, you can move the cut along the shape direction by dragging the snap point.
