| Product(s): | ProSteel |
| Area: | Detail Style |
| Subarea: | 2D Display tab |
This section contains the information related to 2D Display tab section of Detail Style of ProSteel CONNECT Edition. These dialog tabs offer the opportunity to specify the display type of the component parts (centerlines, drill holes, hidden edges, etc.), which line types have to be used and which special default settings have to be valid for the different detailing types.
2D Display > Groups > Cuts:
