| Product(s): | Promis.e | ||
| Version(s): | through 08.11.13.96 and Connect Update 3 | ||
| Area: | Installation_Configuration | ||
| Subarea: | N/A |
The per-user application data folder stores information related to individual users' preferences as modified via the Promis.e interface. This path cannot be altered.
Note: The "Application Data" and "AppData" folders are normally hidden. The "Show hidden files and folders" option must be enabled in Windows' Folder Options in order to find the paths described below.
The per-user application data folder and its contents are generally recreated at Promis.e startup if renamed or deleted. This technique can be used when corruption is suspected.
Windows 10 :
C:\Users\(current login)\AppData\Roaming\Bentley\Promise
Alternatively:
%APPDATA%\Bentley\Promise
Windows 10, Windows 8.1, and Windows 7:
C:\Users\(current login)\AppData\Roaming\Bentley\Promise V8i
Alternatively:
%APPDATA%\Bentley\Promise V8i
Substitute "(A)" for "(M)" in the following paths if using promis.e for AutoCAD.
Windows 8.1, Windows 7, and Windows Vista:
C:\Users\(current login)\AppData\Roaming\Bentley\promis-e V8i(M)
Alternatively:
%APPDATA%\Bentley\promis-e V8i(M)
Windows XP:
C:\Documents and Settings\(current login)\Application Data\Bentley\promis-e V8i(M)
Alternatively:
Windows Vista:
C:\Users\(current login)\AppData\Roaming\ECT\promis-e 2007
Alternatively:
%APPDATA%\ECT\promis-e 2007
Windows XP:
C:\Documents and Settings\(current login)\Application Data\ECT\promis-e 2007
Alternatively:
[[Application Data (per-user configuration) - Substation]]
Display Hidden Files and Folders in Windows XP
Display Hidden Files and Folders in Windows 7
| Original Author: | Matt_P |
