| Product(s): | Promis.e | ||
| Version(s): | through 08.11.13.96 | ||
| Area: | Installation_Configuration | ||
| Subarea: | N/A |
The program data folder contains program related files that require permissions beyond what many users have or what Windows allows for the [[Program folder - promis.e|Program folder]]. These files include:
This path cannot be altered.
This article does not imply compatibility with listed operating systems. Consult the [[Compatibility Chart - promis.e|Compatibility Chart]] for that information.
Windows 10, Windows 8.1, and Windows 7:
C:\ProgramData\Bentley\Promise V8i
Substitute "(A)" for "(M)" in the following paths if using promis.e for AutoCAD.
Windows 8.1, Windows 7, and Windows Vista:
C:\ProgramData\Bentley\promis-e V8i(M)
Windows XP:
C:\Documents and Settings\All Users\Application Data\Bentley\promis-e V8i(M)
Path is the same as the [[Program folder - promis.e|Program folder]] path. Files listed above will be in this path and not in a Config subfolder.
| Original Author: | Matt_P |
