| Product(s): | ProSteel | ||
| Area: | MicroStation CONNECT Edition Basics | ||
| Subarea: | Point Cloud | ||
This wiki explains how to attach the laser scanned model in ProStructures using Point Clouds.
1. Search Point Clouds in the Search Ribbon and open it.
2. Go to File > Attach.
3. Following are the laser scanned file types that you can attach.
In this way, you can attach the laser scanned model in ProStructures using Point Clouds.
