How to use Object View commands?
 Product(s):ProStructures
 Version(s):CONNECT Edition (10.XX.00.XX)
 Area:Navigation Commands
 Subarea:Object View commands
 Original Author:Vyanktesh Nama, Bentley Product Advantage Group
Controlling the views within ProStructures is a great way to optimize the usage of the software. In ProStructures you can use the command Object View to manipulate the view easier and gives you more speed and accuracy working within the model. Below is a demo video on how to use the following two command.
Object View Centered  : It creates a view of the object which sets the UCS origin from the selection point to the centerline.
Object View at a Point  : It creates a view of the object which sets the UCS origin at your selection point.
See Video
