| Area: | Navigation | ||
| Subarea: | Search Objects | ||
In this wiki, we are going to learn how to search the objects in the 3D model with object properties using Explorer tool.
1. Under the Steel | Concrete workflow, left click on the Explorer located at Home > Common Tools > Explorer.
2. In the Explorer dialog, go to Items tab and follow the steps shown in the below image. In the Add Criteria field, search your required property e.g. BarMark then select it and hit Enter key.
3. Now, enable Transparent, Zoom, and Isolate buttons, type the Bar Mark number, and hit enter to see the search result.
In this way, you can search the objects in the 3D model with object properties using Explorer tool.
