| Product(s): | ProSteel |
| Version(s): | All |
| Area: | Detail Center & Drawing Creation |
| Subarea: | Detail Center |
| Original Author | Roger Belen, Bentley Technical Support Group |
| Updated By: | Vyanktesh Nama, Bentley Technical Support Group |
After modelling a project the next stage is Detailing or creating 2D drawings.
The Detailing part of ProStructures is controlled by the Detail Center. The following information will tell you the status of the elements by looking at its colour representation.
GREY : Parts not Processed.
BLUE : The detail block of the part was created, it is not inserted in the 2D drawing and it does not need updating.
YELLOW : The detail block of the part was created, it is not inserted in the 2D drawing and it needs updating.
GREEN : The detail block of the part was carted, it is inserted in the 2D drawing and it does not need updating.
RED : The detail block of the part was created, it is created in the 2D drawing and it needs updating.
