| Product(s): | ProSteel |
| Version(s): | All |
| Area: | Detail Center |
| Subarea: | Parts tab |
| Original Author | Roger Belen, Bentley Technical Support Group |
| Updated By: | Vyanktesh Nama, Bentley Technical Support Group |
ProSteel Detail Center Settings for Display Command gives the user the option to filter how the display is going to look like. There is an option to view it in a Standard way or as a User defined. The video below will show an example of a User defined settings such as Display Class and Area Class. It will also show how to manage the files sorting it and listing it as a Group Structure, Only Single Parts and Group and Single part.
