| Product(s): | ProSteel |
| Version(s): | All |
| Area: | Detail Center |
| Subarea: | Settings tab |
| Original Author | Roger Belen, Bentley Technical Support Group |
| Updated By: | Vyanktesh Nama, Bentley Technical Support Group |
In ProStructures there is an option to create Connection Details or Detail Joints. In order to detail these joints you need to enable a setting in the Detail Center. This WIKI will show you how to turn ON/OFF display of the Connection/Detail joints.
1. Open ProStructures.
2. Launch Detail Center Standard > Settings Tab > Enable Scan Joints.
