| Product(s): | ProSteel |
| Version(s): | All |
| Area: | Detail Center |
| Subarea: | Settings tab |
| Original Author | Roger Belen, Bentley Technical Support Group |
| Updated By: | Vyanktesh Nama, Bentley Technical Support Group |
When selecting parts in the Detail Center Parts Tab the elements are not showing in the model. See below which setting to select to enable this option.
1. Launch the Detail Center go to > Settings Tab.
2. Under Actions if Selection > enable Show Part In Model.
