| Product(s): | ProSteel | ||
| Area: | Detail Center | ||
| Subarea: | General | ||
This wiki explains how once can identify non-positioned parts in the model using Detail Center.
1. Please make sure to switch on the Show part in model in the Settings tab.
2. In the Parts tab > Model > Loose Element section, you can select the non-positioned part that has a three question mark (???) which will then highlight in the 3D model as shown in the below image.
In this way, one can identify non-positioned parts in the model using Detail Center.
