| Product(s): | ProSteel |
| Version(s): | All |
| Area: | Detail Center |
| Subarea: | Parts tab |
| Original Author | Johannes Michalowsky, Bentley Technical Support Group |
| Updated By: | Vyanktesh Nama, Bentley Technical Support Group |
Maintaining theĀ location of Position flags when updating 2D drawings.
Normally Position flags will be at the optimized place, if one wants to keep the manual adjusted place the following steps have to be taken.
1. Open Detail Center.
2. Open the context menuĀ under parts tab and choose Update Protection.
3. Then choose the objects you want to protect from updating.
