How to change the default Preview display View window for 2D drawing in Detail Center?
 Product(s):ProSteel
 Version(s):CONNECT Edition (10.XX.00.XX)
 Area:Detail Center
 Subarea:Settings tab
 Original Author:Vyanktesh Nama, Bentley Product Advantage Group
This wiki explains how once can change the default Preview display View window for 2D drawing in Detail Center.
Steps to be follow
1. Go to the DetailCenter > Settings tab, here click on the Preview dropdown and select the required View window number.
In the above example, we have selected View window 4. Now, when we preview any 2D drawing from the DetailCenter then the Preview window will open in View 4.
