| Product(s): | ProSteel | ||
| Area: | Detail Center | ||
| Subarea: | Settings tab | ||
In this wiki, we are going to see how to create an anchor plan at different level.
1. Measure the level at which you want to create new anchor plan. E.g. your columns starts at level 2000 units.
2. Open Detail Center Standard, go to Settings tab and enter your level value in the Zero Level (z) field (say 2000).
3. Go to Parts tab and reload all the parts in the detail center.
4. Now, assign anchor plan to your detail style and preview the drawing. You will now see the new anchor plan at the entered level.
In this way, you can create an anchor plan at different level.
