Error - 1603, installation failed, fatal error
 Product(s):Promis.e, Bentley Substation
 Version(s):through 08.11.12.137
 Environment:N/A
 Area:Installation/Configuration
 Subarea:N/A
Error or Warning Message
During installation, the following or similar error message is displayed and the installation is rolled back.
Error=1603
Installation failed: fatal error occurred during installation
Explanation
This error has been encountered after specifying a different path than the default local path for the Data folder during installation. The problem path may be a network location.  The problem is likely that the SYSTEM account does not have Full Control of this other path.
According to a Microsoft knowledgebase article (http://support.microsoft.com/kb/834484), possible causes of the 1603 error are:
How to Avoid
Install using the default Data folder path, then move or copy the Data folder after installation is complete. Configure the software to use the new paths on the [[Setup]] dialog.
In one case, the above issues did not seem to be causing the 1603 error for the user as far as they could tell. The user was finally able to install promis.e by running the promise.msi file found in the "C:\BentleyDownloads\promise_08.11.xx.xx" folder instead of running the setup.exe file.
[[promis-e Data folder]]
[[Substation Data folder]]
External Links
 Original Author:Matt_P
Keywords: network, share, tsclient
P/S: 83630, 500000096476
