| Product(s): | ProSteel | ||
| Area: | Drawing Production | ||
| Subarea: | Settings | ||
In the Detail Center Standard, the default views such as Top View, Front view, Isometric view, etc. are generated by default.
Sometimes these views may not appear in the model. There is a separate setting for this that needs to be enabled. Please follow the steps below to resolve this concern.
1. Under the Steel Workflow, navigate to the Detail Center Standard tool located under the Drawing Production tab.
2. In the Detail Center dialog, click on the settings tab and enable the option ‘With Basic Views’
3. This will load all the basic views which will be generated automatically and will be visible under the parts tab.
