| Product(s): | Promis.e | ||
| Version(s): | 08.11.08.xx - 08.11.11.85 | ||
| Environment: | 64 bit OS and 64 bit AutoCad | ||
| Area: | Installation/Configuration | ||
| Subarea: | N/A |
A message indicating that the software can't install or can't find the AccessDatabaseEnginex64 comes up during installation or at startup:
Information
Can't find AccessDatabaseEngine for x64.
You need install AccessDatabaseEngine before run AutoCAD version promis.e on 64-bits system.
This error occurs when the 64-bit AutoCAD version of promis.e is installed on a system that already has an incompatible version of the Microsoft Office products installed. Microsoft does not support and will not allow both the 32-bit and 64-bit versions of the Office suite of products to be installed on the same machine. In order for the promis.e 64-bit version to truly operate as a 64-bit program, it requires the AccessDatabaseEngine_x64, as described in the Install Guide, and in the [[Compatibility Chart - promis.e|Compatibility Chart]].
If you do not have the 64-bit version of AutoCAD and erroneously downloaded and installed the 64 bit version of promis.e, please uninstall it and install the correct 32-bit version.
Note: AutoCAD does not support running the 32-bit version of AutoCAD on a 64-bit OS, so if you have a 64-bit OS, and intend to run the AutoCAD version, it must be the 64-bit version.
If using Microsoft Office 2010, install the 64-bit version of Microsoft Office 2010.
If using Office 2007 which is 32-bit only, or Office 2016 64-bit, or Office 365 64-bit, or not using Microsoft Office, download and install AccessDatabaseEngine_x64.exe 2010.
If you want to use the 64-bit version, but do not have a 64-bit version of Microsoft Office available, you could install promis.e on a machine with no Microsoft Office installed, and it would install the required Access Engine automatically. Some users in the past have done this by setting up a Virtual Machine environment for promis.e so their main system could still have the 32-bit Office version.
You could switch to the Standalone version of Promis.e which does not use an AutoCAD based engine, and does not have this limitation on 64-bit Operating Systems. It will run on either a 32 or 64-bit OS, with no restriction to the Office version.
Microsoft Access Database Engine 2010 Redistributable
| Original Author: | Tani_S |
