| Product(s): | ProSteel |
| Version(s): | All |
| Area: | Detail Style |
| Subarea: | Default Settings tab |
| Original Author | Roger Belen, Bentley Technical Support Group |
| Updated By: | Vyanktesh Nama, Bentley Technical Support Group |
How to add Partial Views to show in the 2D files.
Using the ProSteel Detail Styles in the 2D Detail Center, it is possible to add Partial Views.
On your Detail Style > Default Settings > Partial Views.
You can Select Views that you want to be added automatically to your 2D files when it is generated.
Please make the changes and save the Detail Style.
