| Product(s): | ProSteel CONNECT Edition | ||
| Version(s): | 10.xx.00.xx | ||
| Area: | Detail Style | ||
| Subarea: | Object View | ||
| Original Author: | Sandip Kar, Bentley Product Advantage Group |
Sometime it is necessary to display the bolts in 2D Detail Drawing. It mat be in the form of symbolic or real. ProSteel Detail Style has the ability to display the Bolts either in Symbolic or real form.
This document will explain how to display the Bolts in 2D detail drawing.
To display the Bolts in 2D Drawing, you need to navigate to 2D Display > Common in Detail Style. In that tab
1. To display the bolts as Symbolic form just enable 2D bolt which will display bolts as Symbolic one
The outpu will be then
2. To display as real bolt, you need to also enable Real bolts along with the 2D Bolts. Please note that Real Bolts option will be activated when you enable 2D bolts.
The output will be like as below
