| Version(s): | through 08.11.13.140 | ||
| Area: | Installation_Configuration | ||
| Subarea: | N/A |
The following error message is displayed, typically at startup.
Internal Error
UI Error Message: The Microsoft Jet database engine cannot find the input table or query 'Mode'. Make sure it exists and that its name is spelled correctly.
TargetSite: System.Data.DataTable GetTable(Int32, System.String)
DeclaringType: MDBProxy.LocalTools
Attributes: public
MemberType: Method...
The Multi_Lanuage_UI.mdb database should contain a table named Mode. The software is unable to find or read from this table for some reason.
If this resolves the error message but some customizations (custom symbol attributes, custom language phrases, custom dialog text) are missing, compare the suspect Multi_Lanuage_UI.mdb to the one that resolved the issue using Microsoft Access. It may be possible to copy the missing data into the good Multi_Lanuage_UI.mdb file.
If the above process did not resolve the issue, check permissions on the Multi_Lanuage_UI.mdb file and containing folder.
| Original Author: | Bhargav Chintalapati |
