| Product(s): | ProSteel | ||
| Area: | 2D Detail Center | ||
| Subarea: | Detail Style | ||
In this wiki, we are going to learn how to make visible bolts in 2D drawings as 2D Bolts as well as Real Bolts via the 2D Detail Center.
1. Open the 2D Detail Center, which is located at Steel > Drawing Production > Detailing > 2D Detail Center.
2. Now, preview the group which has bolts. Then open the Detail Style and go to the 2D Display > Common, under the Add section check the box for 2D Bolt and click on the Update Preview button. By enabling this option, we can see the 2D bolts as shown in the below image.
3. Now, on the same page enable the Real Bolts option and update the preview to see the real bolts.
In this way, we can make visible the bolts in the 2D drawings as 2D Bolts and Real bolts via the 2D Detail Center.
communities.bentley.com/.../how-to-display-bolts-in-2d-detail
