Product(s): | Promis.e for AutoCAD | ||
Version(s): | through 08.11.11.85 | ||
Environment: | N/A | ||
Area: | Installation_Configuration | ||
Subarea: | N/A |
At startup, the software displays a message indicating "autoload2012x64.scr" or similar could not be found.
The message likely indicates that 32-bit Promis.e for AutoCAD is installed when 64-bit Promis.e for AutoCAD should be. The file cannot be found because it is only included with 64-bit installations.
One indication that 32-bit Promis.e is installed on a 64-bit operating system is that the [[5365|program folder]] for Promis.e is in "C:\Program Files (x86)" instead of "C:\Program Files".
Uninstall the currently installed version of Promis.e and install the version of Promis.e appropriate for the "bitness" of the operating system, in this case 64-bit. The 64-bit version of Promis.e is installed from a different, separately downloaded file than the 32-bit version.
The product name to download would include "x64", such as " promis.e V8i (for AutoCAD) x64".
Downloaded 64-bit installation files for Promis.e for AutoCAD typically begin with "pac64", such as "pac6408111118en.exe"
[[Compatibility Chart - promis.e]]
Original Author: | Matt_P |
Keywords: autoload2010x64.scr, autoload2011x64.scr, autoload2012x64.scr, could not find, Can't find file
