| Area: | Drawing Production | ||
| Subarea: | |||
Many times users may face an issue where they can find that the text is missing from the position flags in the views generated from Detail Center.
Original issue description:
When the drawing is generated in the detail center appear the flags but without position number.
In this wiki, we will learn how to tackle this issue.
1. The above-mentioned issue occurs because of not providing the text style in Detail Style used.
2. First, open the 2D Detail Center.
3. Now, in the detail center, right click on the detail style used and click on the edit style.
4. In the Detail Style Dialog, go to 2D Display > Common> Text Display and provide the text styles and text template.
5. After providing the text style and templates, the corresponding text will appear in the position flags.
