| | Applies To | | |
| | Product(s): | AutoPLANT P&ID XM Edition | |
| | Version(s): | 08.09.03.05 | |
| | Environment: | N/A | |
| | Area: | N/A | |
| | Subarea: | N/A | |
| | Original Author: | Bentley Technical Support Group | |
This is a complete install order for AutoPLANT Products which includes some addition software packages that can be used along side with AutoPLANT. Some of the listed software is optional, depending on which products are being used. See the notes under each software for more information or click on the Readme link to access the programs read first file for more information.
Install Order and Versions
- Support AutoCAD software
- MicroStation V8 XM Edition Software Prerequisite Pack - 08.09.04.01 (ReadMe)
- Required for Bentley View and Bentley Navigator
- Bentley View XM Edition - 08.09.04.51(ReadMe)
- Viewer for Document Manager and Vision
- Bentley ProjectWise V8 XM Edition - Client Setups - 08.09.04.89
- Only needed if running ProjectWise
- Bentley AutoPLANT P&ID XM Edition - 08.09.03.05(ReadMe)
- Bentley AutoPLANT Plant Design XM Edition - 08.09.03.30 (ReadMe)
- 3D piping package which includes Piping, Equipment, Raceways, Isometrics, & SpecGen
- Bentley Plant Framework XM Edition - 08.09.03.72 (ReadMe)
- Upgrade for 3d package, required for SP2 upgrade
- Bentley Process & Instrumentation XM Edition - 08.09.03.44 (ReadMe)
- Bentley AutoPLANT Plant Design XM Edition Service Pack 2- 08.09.03.49 (ReadMe)
- Upgrade for 3d piping package
- Bentley Plant Framework XM Edition - 08.09.04.47(ReadMe)
- Upgrade for framework for all Plant, required for ProjectWise
- ProSteel 3D R18.0 - 08.10.00.17(ReadMe)
- Optional Structural software Package
- Bentley Navigator XM Edition - 08.09.05.70 (ReadMe)
Product TechNotes and FAQs
External Links
Bentley homepage
Bentley LEARN Server
Comments or Corrections?
