| Version(s): | through 08.11.13.96 | ||
| Area: | Find_Replace | ||
| Subarea: | Replace Symbol |
The Replace Symbol tool allows a symbol to be replaced with another symbol on the current page or entire project. The symbol can also be replaced with itself as a means of refreshing it with the most recent version in the catalog.
From the Tasks or ribbon area, select Review/Revise >Revision Management >*Replace > Replace Symbol
Select Search > Replace Symbol
* is used to denote a menu selection that is not necessary in some versions or platforms.
[[Update Symbol]]
[[Exchange Catalog]]
| Original Author: | Matt_P |
