| Product(s): | Pre-XM AutoPLANT applications | ||
| Version(s): | Appliction below version 08.09.XX.XX and above 2.0 | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
You will need to determine what version of Plant Security Manager you have installed. The latest version is 08.06.00.01.
To do this go to Control Panel > Add/Remove Programs scroll down to "Plant Security" and click on "Click here for support information"
You should only have one installation of Plant Security at any given time.
If you show two or more you will need to uninstall all of them and reboot your PC before following the steps below.
