| Product(s): | ProSteel | ||
| Area: | Drawing Production | ||
| Subarea: | Detail Center | ||
In this wiki, we will learn how to enable an additional view for End Plates when they are present in the group drawings.
1. Open the Detail Center Standard and Right-click on the required Detail Style and Edit the Detail Style.
2. In the Detail Style dialog, go to 2D Display>Groups
3. In here, under the End Plates section check the option Display End Plates and save the Detail Style.
4. Now, Generate the drawing and you will observe that another view is created for the endplate of the group.
