| | Applies To | | |
| | Product(s): | AutoPLANT Piping | |
| | Version(s): | 08.11.09.140 | |
| | Environment: | N/A | |
| | Area: | AutoCAD | |
| | Subarea: | Profile | |
| | Original Author: | Justinas Lipnickas, Bentley Technical Support Group | |
AutoPLANT is not supported to run on top of AutoCAD Mechanical in a out-of-the-box installation. To run it with AutoCAD Mechanical, you need to configure it to run with a Vanilla AutoCAD profile, while working with AutoPLANT.
- Install AutoCAD Mechanical 2012 and AutoPLANT v8i SS4
- Launch AutoPLANT v8i
- In Tools->Options->Files remove the following support paths:
- Change the “Main Customization File” to acad.cuix, by default it is located at:
C:\Users\<<User name>>\appdata\roaming\autodesk\autocad mechanical 2012\r18.2\enu\support - The results should look something like this:
- Click OK, Restart AutoPLANT and it will load using Vanilla AutoCAD.
- Go to Tools->Options->Profiles, export AutoPLANT_PDW811ACAD_A005_409 profile, and import it to other computers if necessary.
[[Bentley AutoPLANT]]
