Area Description
| API Builder | Project Description mapping in Excel not correct (needs to match the description in the Help file) |
| ATP | The part number display is not correct, and Update Wiring Diagram reports an error for multiple placement symbols. |
| Balloons | Balloon numbering by the installation is not working correctly. |
| Balloons | Remove limitation for an only a single set of Balloons allowed per part number per page |
| Balloons | An error about balloon pops up when restoring the sample project “Sample Washer”. |
| BOM Explorer | Removing unplaced devices removes device part numbers associated with a BOM Document |
| BOM Manager | An unnecessary record is created in dbo.BMData when the user moves a record to a BOM Document |
| BOM Manager | An unnecessary record is created in dbo.BMDocument when the user attempts to Save without entering a value in New BOM field |
| BOM Manager | Do No Purchase value 'Yes' not saved |
| BOM Manager | An unnecessary record left in dbo.BMData when the user changed Do No Purchase to No while all other user fields are Null or Blank |
| BOM Manager | Brackets [ ] remain in Insert Substation Objects - Symbol By Device ID after the user has renamed a temporary Device Tag |
| BOM Manager | Changes to Parts Database fields are not applied to existing records in the data grid when the user has configured source DB to use SQL Parts Database |
| BOM Manager | Incorrect field display name in Create Custom Part dialog for additional fields being added |
| BOM Manager | Renumbering balloon values skips numbers regardless of balloon setting "No Limitation" |
| BOM Manager | Unnecessary records left in dbo.ParentDeviceAttribute after the symbol is placed |
| BOM Manager | The revision number cannot be displayed in the tree view in time if there are two work orders in the BOM Manager dialog. |
| BOM Manager | Some copied values are missing and an error appears after Running Validation |
| BOM Manager | In BOM Manager dialog, input lower cases letter for installation and location, it should display Capital letters |
| BOM Manager | NoCoded Parts display wrong field value |
| BOM Manager | Mapping the variable Part Number in Options will report an error |
| BOM Manager | Unhandled Error Message when adding part which contains ' character (Single Quote) in a parts database field |
| BOM Manager | Parts database field not updating after the user changes a device's part number |
| BOM Manager | Unnecessary fields populated for Coded parts in dbo.BMData table |
| BOM Manager | Auto-assigned balloon number not within the BOM Document Revision range. |
| BOM Manager | The "memo1" value cannot be displayed in the BOM Manager |
| BOM Manager | An internal error loop when the user selects Show Auto Filter Row |
| BOM Manager | Added new attribute and custom part with the new attribute in the BOM Manager creates an error |
| BOM Manager | Fields in data grid not populated with parts database value for Non-Coded Part numbers |
| BOM Manager | Filtering capability select all doesn't account for filtered items |
| BOM Manager | The device can end up with multiple BOM Document Numbers |
| BOM Manager | Unable to add NamePlate to Nameplate view when "isNameplate" field value is True, when using "Parts Database" record data source option |
| BOM Manager | When new BOM Document Revision is created in the BOM Manager, the user cannot select a different work order |
| BOM Manager | BOM Manager reports an error when adding part from the part database and add the device in the BOM Manager |
| BOM Options | Adding duplicate attributes for Nameplate should not be allowed |
| BOMManager | An error occurs when loading existing work order in the BOM Manager with the user's database and user's project |
| BOMManager | An error message occurs when submitting SAP when the balloon number is blank |
| Command Protection | The Enable command protection toggle is changed to unchecked when initially used without ProjectWise integration and later launched with ProjectWise Integration |
| Components Center | Change local catalog's icon in Catalog Manager as it is same as Insert Symbol by Name |
| Configuration Variables | User not able to Modify Project while using Custom WorkSpace |
| Configuration Variables | Catalog path is empty in the Modify Catalog Paths dialog |
| Configuration Variables | After creating one Parts database based on SQL data, it reports an error with Edit all parts database in the Configuration Variables |
| Configuration Variables | SQL Parts Database path edit removed the connection string details |
| Configuration Variables | Deployment of dbsettings.xml for users doesn't log in to the database as the password is not populated |
| Copy Page | The wire number in the Wiring Manager dialog in not maintained for the newly copied page |
| Copy Page | The wrong installation and location is copied in the newly copied page |
| Copy Page | Wire number's Prefix and Suffix are not preserved for copied pages |
| Copy Project | When trying to Copy Project, Create Project Database dialog pops up |
| Create Symbol | Add a new cross-reference text, the text name is not correct |
| Create Symbol | Change the new tab name from “Balloon Number Attributes” to “Balloon Attributes” |
| Device Usage Chart | An error message occurs when clicking the OK button in the Device Usage Chart dialog |
| DTM | The Substation will crash after selecting the DTM |
| Exchange | Exchange Equipment Number gives Unhandled Exception Error message |
| Graphical Parts List | All the data in the drawings are missing after running Graphical Parts List within ProjectWise environment |
| Help File | The link of Help document needs to be added for Backup Project |
| Help File | The help document is not loaded for AutoBackup Settings dialog |
| Help File | Incorrect Help details for BOM Manager (PartsAttributeMapping) |
| Insert Macro | Click Place Macro button in the Insert Symbol/Macro dialog, the software crashed. |
| Insert Macro | The message “The physical file "" does not exist in catalog directory. ”is displayed when inserting macro from the Components Center |
| Insert Symbol | The software crashed with Multiple Placement of symbol |
| Insert Symbol | Right-click a 3D object, click Properties, it popups error dialog. |
| Configuration Variables | Error “Template file was not found” pops up when we creating the WorkSet with a template. |
| LCM Settings | It should not allow deleting the default attributes for the LCM in Options |
| Lightning Protection | Lightning Protection mast is not generated correctly for the user's project |
| Options | An error appears when adding custom attribute in Life Cycle Manager Settings and selecting Wire Manager |
| Options | An error appears when selecting New Project -> Options -> System options -> Life Cycle Manager Settings |
| Options | Reports error when selecting Options > Life Cycle Manager Settings during the creation of the new project. |
| Options | Component Center is not displayed under System options |
| Options | Add password Encryption for SQL connection in LCM Settings. |
| Parts Database | It reports an error with Opening Parts Database Manager according to the user's data |
| Parts Database | Custom parts database cannot be searched |
| Performance | Substation: Page opening is very slow in substation and opens quicker in Microstation Mode |
| Performance | The performance of Project Publisher in Substation CE Update 6 is slower compared to Update 5 |
| Performance | Project Builder in Substation Update 5 is slower than that in Substation CE Update 4. |
| Performance | Reduce the size of Pending Commands table |
| Performance | Index optimization for performance improvement |
| Plugin | Update symbol plugin updates the Part Number for Part with Additional Part |
| Project Restore | Unhandled / Internal Error message during project restore - Page Table not being populated |
| Project Restore | An error message occurs when restoring user's project |
| Project Restore | Project database not listed in Restore Project dialog |
| ProjectWise | An error pops up after Substation cannot find the local parts database in ProjectWise integration. |
| ProjectWise | Substation reports an error when generating PLC |
| ProjectWise | An error pops up when copying project |
| ProjectWise | Slow performance when opening a file that is already checked out |
| ProjectWise | Catalog categories cannot be created. |
| ProjectWise | "Export unmanaged Copy” of ecad.dgn to users dms creates an error message |
| ProjectWise | ProjectWise Check-in Dialog appears multiple times after selecting “Cancel” to leave file checked out |
| ProjectWise | Cannot close drawing temp file after saving a symbol in symbol creation |
| ProjectWise | An error occurs when copying a page with symbols from PW Explorer |
| ProjectWise | Fail to run this feature in Promis.e with ProjectWise |
| Properties Control | When BOM Document Number and Revision Number are set as a PickList the Properties Control dialog, a user cannot select the value from the drop-down list. |
| Properties Control | Change the options from TEXTBOX to COMBOBOX, the inputted values in TEXTBOX cannot be all list in the dropdown list. |
| Properties Control | The values in the Properties control dialog should display the Value Prompt in LCM Custom Attributes dialog. |
| PW Explorer Plugin | An error occurs when clicking BOM Manager tab in Options when creating a project from PW Explorer Plugin |
| PW Explorer Plugin | The Substation will be closed when running Update Server Copy from PW Explorer |
| Reports | The sorting variables display is not correct after adding to the sorting field |
| Reports | BOM_Substation_Qty report filters for Work Order, BOM Document Number, and Revision Number not filtering as required |
| Restore Project | Projects tree needs to be refreshed in order to list the project restored |
| Restore Project | The restore dialog always pops up when launching Substation (only if user double clicks on .PRJ file prior to launching substation) |
| Shortest Distance | Shortest distance crashes and reports error |
| Symbol Creation | Duplication of the symbol while modifying the symbol |
| Symbol Creation | Creating a new symbol based on Cell Graphics doubles the symbol graphics after the symbol is saved |
| Symbol Creation | Using shared cells option produces duplicate symbols after the symbol is edited |
| Symbol Placement | Special character ' in symbol name causes unhandled exception error |
| Text Settings | Change the default Text Type to Symbol Text in the Edit Text format dialog if the selected circuits include the Symbol Text. |
| Text Settings | Right-click a Text->Text Settings, the Underline Space does not work in the Edit Text Format dialog. |
| Title Block Designer | The warning information is not correct when saving the same name title block in a path. |
| Wiring diagram | Cable cross-references symbols' wiring diagram connection is not updated properly |
