| Product(s): | AutoPLANT Piping | ||
| Version(s): | 08.11.05.36 | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
| Original Author: | Jesse Wolfe, Bentley Technical Support Group | ||
In the past we have received multiple requests for the option to allow Components of different facings to join to each other. As a result, this option was added as a Component Preference. The steps below detail the process to enable this feature.
3. In the Result Field pull-down menu, select the option for AT_IGNORE_FACE and Press OK
4. You should now the new Component Preference in the Component Preferences menu. Toggle it on and off to adjust whether
AutoPLANT restricts connections based on Facing.
**For further Details on Component Preferences and how to make this change globally for all New Drawings in a Project, please see the article Understanding Component Preferences in AutoPLANT linked below**
Understanding_Component_Preferences_In_AutoPLANT
