| Product(s): | ProSteel | ||
| Area: | 2D Display tab | ||
| Subarea: | View tab | ||
This wiki explains the use of 2D Grouping per object option in the Detail Style.
Turning on this option, enables the selectable 2D output as grouped objects in the 2D drawing for the views.
