| Product(s): | ProSteel |
| Area: | 2D Display - Detail Style |
| Subarea: | Line Display |
| Original Author | Roger Belen, Bentley Technical Support Group |
| Updated By: | Vyanktesh Nama, Bentley Technical Support Group |
There are four different options on how we can control the 2D Line Display in the Detail Style (> 2D Display > Common > Line Display) as listed below.
3. From Part Family
4. From Detail Style
In this wiki we will try to explain the use of Configuration for 2D Line Display in Detail Center. From Configuration are the default Layers/Levels set within ProStructures. The settings can be found in the Options / Global Settings.
1. Open the Global Settings or Options by holding the right mouse button in the View window and then click on the Options.
2. Go to Configuration / Isometric view > Layer. Look at the screenshot below. When using “From Configuration” option your 2D output will use the layers set from here.
3. These levels we can set as per our requirement for the ProSteel objects while placing them in the model or we can just select the Configuration file value which will then automatically identifies correct Label and accordingly sets the level. For example, in the below image of Shapes dialog before placing the object we can set level as per the choice.
