| Product(s): | ProSteel |
| Version(s): | All |
| Area: | Detail Style |
| Subarea: | 2D Display |
| Original Author | Roger Belen, Bentley Technical Support Group |
| Updated By: | Vyanktesh Nama, Bentley Technical Support Group |
You can add an Elevation Symbol into a group which will then be expanded during Detailing.
1. Please use the Command shown below.
2. Edit the Detail Style and make sure the 2D Elevation Symbols is selected.
