| Product(s): | Promis.e CONNECT | ||
| Version(s): | 10.00.XX.XX to 10.05.XX.XX | ||
| Area: | Migration - Promis.e CONNECT | ||
| Subarea: | N/A |
This article discusses how to migrate your V8i projects to the Promis.e CONNECT Edition using Configuration Assignment Utility.
In Promis.e V8i, the application relied on its own setup configuration which was stored in the setup.xml file to locate the dataset, connect to the project database, and specify various default settings. In Promis.e CONNECT Edition, however, this setup.xml is replaced by the native Power Platform configuration system like the WorkSpace and WorkSet configuration. When the Promis.e V8i projects are migrated to CONNECT it will assign WorkSpace & WorkSet to the Project's during the process. After the Projects have been assigned the WorkSpace and WorkSet they can be opened in Promis.e CONNECT.
Note: Power Platform is the MicroStation core application that underlies the Promis.e CONNECT Edition product.
See below short video for steps on how to use Configuration Assignment Utility for Migrating the projects from Promise V8i to Promise CONNECT
| Original Author: | Satish Saptasagar |
