| 279865 | [Run Reports] BOM_Substation_Qty report filters for Work Order, BOM Document Number, and Revision Number not filtering as required | | | |
| 289215 | When symbol Attribute display is made hidden it gets changed to visible | | | |
| 336936 | [Run Reports]The BOM Number and Revision Number from the Symbol attributes not listed in the filter list. | | | |
| 337084 | [Load Data by BOM Document]Rename revision and BOM Document number is not correct. | | | |
| 337520 | [Load Data by BOM Document]Remove revision and BOM Document number, the tree view should be refreshed automatically. | | | |
| 347124 | [Project Manager][ProjectWise Integration] Project Manager doesn't not show checked out icon after user closes page without checking in page | | | |
| 347130 | [Navigate][ProjectWise Integration] navigate function automatically checks in file when user selects close at PW Check in prompt | | | |
| 354590 | [Work Order Manager]The Work Order sort order is not correct if the work order name are numbers. | | | |
| 358389 | [BOM Manager]The work order sort order is not correct if they all numbers. | | | |
| 358807 | [Project Manager-Multiple database] It will close the page of the active project if users just click another project | | | |
| 358883 | [BOM Manager]After edit several parts, the select all toggle cannot select all | | | |
| 379908 | [PW-Project Manager] Project Manager Tree should default to ACTIVE Project and shows the ACTIVE Projects Page list under the Subfolder | | | |
| 382558 | [Balloon Restore Project]Restore a project with balloon from BOM Manager, change the balloon number in the properties dialog, the balloon number will not change in the drawing. | | | |
| 382570 | [BOM Manager-Requirement Date]It cannot assign Requirement Date to the BOM part that has been placed on the drawing in BOM Manager | | | |
| 393308 | [DataManager][Pending] It always prompts the pending page when changing the Device ID in the Data Manger in the project | | | |
| 393860 | [BOM Manager][Nameplates] missing symbol text in BOM Manager after user moves Nameplate devices to another BOM Manager Tree Node. | | | |
| 406299 | Socket error when attempting to run multiple sessions of application on same machine | | | |
| 410872 | [BOM Manager][Submit] and [Validate] Unhandled Error "Input string was not in a correct format" | | | |
| 411479 | [BOM Manager] Unhandled Error when user changes Group By to Balloon after setting balloon number values using Group by Device | | | |
| 431645 | [Configuration Variables] The catalog only defined under WorkSet and imported catalog is not displayed in Catalog Manager | | | |
| 381440 | Wire Label: Wire label offset on vertical wire not same as horizontal wire | | | |
| 368900 | [PW_Create Electrical Project/Page] There is no response when click Create Electrical Project command on PW Explorer side | | | |
| 367499 | Symbol text with "^" for next line have issue with visibility toggle in symbol text option | | | |
| 372742 | Replace Family command creates duplicate families with different sub id for the parent and child symbols | | | |
| 394625 | [Symbol Settings] Mirror symbols in the default sample projects are wrong | | | |
| 394615 | [Wire link] It should add the right click menu command "Symbol Settings" for the Wire link symbol | | | |
| 394614 | [Wire Link] Wire link tag should not be displayed after rotate wire link | | | |
| 358364 | [Wiring][Multi-wire] Cannot place Multi-wire. | | | |
| 384062 | [BOM Manager]The Insert Balloon button should not be useful when no device is selected in the BOM Manager dialog. | | | |
| 369990 | [BOM Manager]Load data by BOM Document, click the Submit BOM, it always popups “There is nothing to submit”. | | | |
| 366736 | [BOM Manager]Sometimes edit several parts together to an work order, the parts are not in the same work order. | | | |
| 292414 | [Run Graphical Plan]It can only display one part number in the output graphical plan drawing. | | | |
| 417539 | [PW_NetworkDriveCatalogs] Error appears while click Insert Symbol By Name after rename PW Managed WorkSpace Catalogs folder | | | |
| 310660 | [Configuration Variables_PW] Set ELEC_SHOW_PWCHECKIN_DIALOG = False, the Check in dialog still pops up | | | |
| 314732 | [BOM Explorer]Add attributes for a symbol in BOM Explorer, the attributes name display is not correct after reopen the BOM attributes dialog. | | | |
| 429220 | [Balloon][Bacup Restore]Create a project with construction drawing, and reference 3d views, place balloon by BOM Manager in the drawing, backup, then restore, the balloon is missing. | | | |
| 404794 | [Backup Restore]Backup a project, and then restore it, the symbol right click menu is lost. | | | |
| 230802 | [Symbol Creation Wizard] Array option places attributes at incorrect x and y coordinates | | | |
| 383012 | [Create Macro]Open the special page in the user’s project, and create macro, it popups error dialog. | | | |
| 381905 | [BOM Manager Balloon]The balloon number is not correct if inserting balloon after modifying the balloon number. | | | |
| 362302 | [Command Protection] Turn OFF Draw Wires,try to place Multi-polywire,there‘re still some segments placed in drawing | | | |
| 331290 | [Martian] It should be labeled with the translation character for Create WorkSpace and Create WorkSet | | | |
| 231087 | [PW Cloud] Remove unnecessary CopyOut() functions from the source code | | | |
| 419274 | [PW-Create Page] Create page will report error with PW project | | | |
| 391659 | [Performance] improve open/close dgn performance | | | |
| 386354 | [Create 3D Macro] Creating 3D macro will crash to the desktop with projects | | | |
| 385665 | [SQL parts database]An error will pop up if you don't have SQL sa password. | | | |
| 384815 | [BOM Manager] [Address fields] Unhandled exception occurs when entering single quotation marks (’) in address fields 1-7 | | | |
| 365022 | Software Crash when create page macro | | | |
| 313915 | [PW Explorer Plug in] Cannot update project properties immediately from PW Explorer | | | |
| 287918 | [Place Labels-Report] It cannot generate the correct partnumber quantity with the SubID symbols in Place labels report | | | |
| 385608 | [Balloons] Add new Engineering Design Consideration for Orphaned Balloons | | | |
| 385632 | [Balloons] Add New Tool to Locate Orphaned Balloons on active page | | | |
| 385636 | [Balloons] Add new tool to remove all unused Balloon Named Groups within active page | | | |
| 385641 | [Balloons] Add new Tool to remove all Orphaned Balloon records from SymbolBalloonGroup table for active Project | | | |
| 391827 | [AutoBackup] Support autobackup function in the environment with multiple databases | | | |
| 283637 | [Balloons] Enhancing Balloon editing and updating functionality (Updates shouldn't change custom arrangement) | | | |
