| Version(s): | CONNECT Edition (10.07.00.79) & Above | ||
| Area: | Setup & Customization | ||
| Subarea: | Configuration Setup | ||
This wiki explains where the Manage Configuration settings get stored in ProStructures.
The Manage configuration settings are stored in the Configuration.xml file which is located in the below path. Please refer to the below snapshot.
Path: C:\Users\Vyanktesh.Nama\AppData\Local\Bentley\ProStructures\10.0.0\prefs
